rocker arms
Old Sep 10, 2010 | 05:19 AM
jay173's Avatar
rocker arms
On the 89 chevy 305 was it possible to upgrade your rocker arms and the ratio?
Old Sep 10, 2010 | 07:21 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: rocker arms
yes , the most popular i feel are the 1.6 roller tips . comp cams 1416-16 are a good choice . i have those myself . a good time to change valve seals . but , don't expect a seat of pants difference in performance . good luck .
Old Sep 14, 2010 | 01:09 PM
jay173's Avatar
Re: rocker arms
Well for my 89 the intake is intake .234 exhaust .257 lift for the tbi motor.
So my question is with flat top pistons and the 9.3:1 compression ratio what is the max lift you can run on these engines?
Old Sep 14, 2010 | 01:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: rocker arms
On stock engines, it's the valve guide clearance that limits things, not the piston-to-valve clearance. You can get around .475" or so, depending on tolerances, before the retainer smacks into the valve seal.
Old Sep 14, 2010 | 04:24 PM
jay173's Avatar
Re: rocker arms
Oh ok thanks,
I was born in the 80s so I was wondering why they didnt use a better cam in the camaro tbi or was it to save money and just drop in the truck version on an rs.
Old Sep 14, 2010 | 10:54 PM
jay173's Avatar
Re: rocker arms
If that where the only thing then I could run a 1.8 rocker ratio and my engine isnt that old so valve guides wont be an issue.
Because my exhaust lift would only be .462 so what do you mean by valve guide clearence?
Ed1LE
Sep 30, 2018 09:14 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
