Car Popping
Old Sep 13, 2010 | 12:29 AM
Kozusnik's Avatar
Car: 1986 Sport Coupe Camaro
Engine: V6 2.8L vin S 173ci - MFI GAS
Transmission: 5 Speed Manual
Car Popping
Hey, Everyone so I have a 1986 2.8 Camaro Fuel injected.... But anyways when I going up a kill or when car is under load it is making a popping noise... I just got the car not to long ago but these are the parts I have put into it...
-Spark plugs
-Wires
-Cap and rotor
-Coil pack
-Fuel filter
-Air filters
-Oil change
-Oil filter
-Power steering pump belt
-PCV Valve
-Mass Air Flow Sensor
Ran sea foam thur the oil intake and gas....
Oh also fuel gauge is stuck on past full.....
Please
Old Sep 13, 2010 | 05:10 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Car Popping
When did the popping develop? Did it happen after you did the cap and rotor? Have you verified your timing is correct? Have you verified your firing order is correct?
Old Sep 13, 2010 | 08:07 PM
Kozusnik's Avatar
Re: Car Popping
- Firing order is right
- Have not checked timing because it seems to run really good most of the time.
- Cap and rotor not sure because it was changed the day after I got the car... but i did check the cap and rotor to make sure its tighten down good....
Thanks for getting back to me so fast
Old Sep 13, 2010 | 08:24 PM
84transam87's Avatar
Re: Car Popping
where is the popping coming from exactly?? exhaust?under the hood?? i used to have an 86 TA that i guess you could say popped when it was floored and it had to do with a bad spark plug wire
Old Sep 13, 2010 | 09:58 PM
Kozusnik's Avatar
Re: Car Popping
Sounds like its coming from under the hood... But it does back fire a lot when you first start out COLD.
Steven 86IROC-Z
May 24, 2026 04:52 AM
RazorN8
Jan 7, 2022 11:44 AM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
