EST question
Old Sep 15, 2010 | 10:53 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
EST question
I have a small light tan wire right near my coil. When I disconnected it , my tach stopped working. There is also a darker tan wire with a black stripe near my a/c stuff/black box . Which one is the EST wire? I disconnected the one near the coil last time and reset my timing. WTF?
Old Sep 15, 2010 | 11:01 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: EST question
the one near your ac box stuff which is darker tan with black wire should be EST wire. thats used to set base timing.
The other wire is the tach signal wire and hence why it stopped working when unplugged
Old Sep 15, 2010 | 11:11 AM
ninetyone's Avatar
Axle/Gears: 3:42
Re: EST question
So, then what did I set my timing too then? I definately moved the distributor and it runs fine.
Old Sep 15, 2010 | 11:31 AM
Mr. Notorious's Avatar
Re: EST question
You're going to have to get a timing light and check the balancer to see where you set your base timing. From there the computer takes over the timing...
Old Sep 15, 2010 | 12:24 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: EST question
I know that. I thought at the time i set it to 6 degrees. Then i reconnected that "wrong" wire". LOL. So, it runs better ,but where do you think i actually set it to?
Old Sep 15, 2010 | 12:47 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: EST question
Given the year, total timing at idle is usually around 20 deg. 6 is usually the base. With 6 deg total timing WITHOUT the EST disconnected, then actual base now is probably 14 deg less than 6
I'd reset it. I wouldnt expect it to run better with that little timing
MustangBeater20
Oct 29, 2022 09:20 PM
1992Vortec
Aug 31, 2015 08:05 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
