help car quit running after oil pan gasket change
Old Sep 17, 2010 | 01:48 PM
DeimonFrost's Avatar
Car: Camaro
Transmission: Turbo
I recently bought a 82 camaro crossfire with a 350. A few days after i got it i replaced the oilpan gasket and changed the oil, when i tried to start her the fuel pump had went out. i replaced that and the relay and cleaned the injectors, ive checked fuel lines and filter all is ok. I did not pull the engine I did it from under the car. It has a new timing chain, Starter and altenator. When I tried to fire her up she will try and turn over but is getting little fuel to the injectors and will not start. Any other suggestions because I am not sure what else to try.
Old Sep 18, 2010 | 08:51 PM
Car: Camaro
Transmission: Turbo
Re: help car quit running after oil pan gasket change
she's alive second guessed the wiring and it was right the first time
Old Sep 18, 2010 | 09:56 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Good to hear!
Old Sep 19, 2010 | 11:24 PM
Car: Camaro
Transmission: Turbo
thanx had me frustrated for awhile!!!!
maroe624
Apr 16, 2017 08:29 AM
B_Dubya
Aug 26, 2015 05:09 PM
MY87LT
Aug 17, 2015 08:43 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
gwade12
Aug 8, 2015 08:17 AM
