Piston to Valve clearance
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Ok guys....wondering about putting 1.6 rockers on my 383. I believe I have plenty of room....just wanting to run it by y'all as well. Flat top pistons with 4 valve reliefs....3.4cc. .010 piston to deck clearance with a .041 thick gasket and 65cc AFR heads and the GM 847 cam.
I have 1.52s right now...just something I'm thinking about....probably won't gain much going to the 1.6s though.
What's your opinion?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Piston to Valve clearance
Very unlikely to be a problem, but the way to know for sure is to check.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Most of those types of pistons only have valve reliefs for 2.02" valves, while the most recent AFR 195 heads have been getting 2.055" valves, and the 210s have long been getting 2.08" valves. So if those are the heads you have, then you'd better pull one, get the clay, and check it the right way.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I had around .120" on intake and .080-.090 exhaust which is bare minimum clearance.
You should be fine on the 847 cam with .010 deck/.041 gasket. But its nice to check to be sure.
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Thanks guys...that's what I was thinking as well. If I pull the heads to check, then I'll probably go to a smaller gasket in thickness to get a better quench and just add a tiny amount of compression.
When I was building the engine, I took the edge of the valve reliefs and rounded/smoothed them from there jagged edge to reduce detonation so I did clearance them a tiny bit for the bigger valve without thinking about it....lol.
New2Chevy
Sep 28, 2015 12:35 AM
355tpipickup
Sep 13, 2015 11:35 PM
