92 GTA Fuel pump
Old Sep 21, 2010 | 10:29 AM
ryansws6's Avatar
Car: 00 TA
Engine: LS3 408
92 GTA Fuel pump
I've done swaps on my 4th gens and I'll be picking up this GTA soon and I wonder if I MUST drop the tank? I didn't have to with my 4th gen. I understand the hardlines are an issue so I'd have to drop it...
Old Sep 21, 2010 | 11:03 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: 92 GTA Fuel pump
Yes. The only way around dropping the tank is if you want to cut a fairly large access panel in the rear floor.
Old Sep 21, 2010 | 11:38 AM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
DO NOT CUT ANYTHING.
Just drop it.
Old Sep 21, 2010 | 01:27 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Here we go again, lol. This is a highly debated issue.
Old Sep 21, 2010 | 01:36 PM
ryansws6's Avatar
Car: 00 TA
Engine: LS3 408
Well on my 408 TA I did cut a hole. All my exh is welded up and I couldn't drop the tank. I made a nice patch panel, sealed it and rivets. All under the carpet. I understand the hole has to be much larger due to the hard lines. However if the exh isnt welded on then I will drop the tank...
Old Sep 21, 2010 | 02:42 PM
Lol I had to do it. Seen it all over the place on the boards. If you do it right, and are able to seal it back up correctly, heck even make a door out of it, then I'm all for it. But not when it looks like this.
What the PO did to my GTA.
Old Sep 21, 2010 | 09:30 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
I have seen some access doors that came out pretty nice.
Old Sep 22, 2010 | 05:56 PM
ryansws6's Avatar
Car: 00 TA
Engine: LS3 408
WOW thats a hack job! Thats the worst I've ever seen! I just ask what did he use to cut the lines?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
gta90
Sep 15, 2015 04:00 PM
Winchester1094
Aug 18, 2015 10:23 AM
92camaroJoe
Aug 13, 2015 06:07 AM
