lt1 swap
Old Sep 22, 2010 | 04:24 AM
lt1 carb's Avatar
lt1 swap
Osm I'm at the last leg of the swap I'm doin an lt1 carb conversion got pretty much everything done except the fuel deliverly my question is how do I hook up the fuel pump the stock one is dead and I have a procomp pump any help would be helpful
Old Sep 22, 2010 | 12:20 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: lt1 swap
Not sure if there is any way to put a mech. pump on an LT1, but you should drop the tank and replace the dead pump with a TBI piece. Than run a return style regulator to the carb and set it at the correct PSI that your carb requires.
Old Sep 22, 2010 | 08:39 PM
lt1 carb's Avatar
Re: lt1 swap
Well to save cash I have a pro comp fuel pump the problem is I don't know how I would wire it from the rear of the ca I want to wiring thru the ignition switch and have a fuse connected to it but how would I got to wiring it up
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
