flywheel question and starter question
Old Sep 20, 2010 | 09:57 PM
endo666's Avatar
Car: 84 Camaro
Transmission: Stock 5 Speed
I am swapping from a 305 to a 350. I have a T5 tranny that i am going to still be using.
I have picked out 2 flywheels and would like to know what justifys the price difference.
ONE
TWO
they are 10.4 in which is stock as my clutch disc is a stock oem that i replaced only about 6K miles ago. and this flywheel is a lighter one like what came stock on my 84 camaro.
or should i go with a different flywheel?
next question i need a starter can someone recommend me one.
Old Sep 20, 2010 | 11:24 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: flywheel question and starter question
What's wrong with your stock flywheel and starter?
Old Sep 21, 2010 | 05:58 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Use "TWO"
The re-man LT1 starters are the best priced lightweight starters. Just specify that it's for a '95 Z28, for example.
Old Sep 21, 2010 | 07:43 AM
endo666's Avatar
Car: 84 Camaro
stock flywheel is for my 84 305 which from what i have heard is a 2 piece rear main which has a different bolt pattern from what cam on the 350 that i have with a 1 piece rear main.
correct me if im wrong please.
and if i have to switch my flywheel and the new one has a different number of teeth i will need a new starter
Originally Posted by Atilla the Fun
Use "TWO"
cool ill check them out.
Old Sep 21, 2010 | 08:34 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
You didn't say that up top.
Have to use the flywheel that fits the engine
1 and 2 pce cranks have different bolts patterns and the engines are balanced differently
Both the flywheels you listed are for later 1 pce engines and have same 153 tooth starter
Old Sep 21, 2010 | 02:55 PM
endo666's Avatar
Car: 84 Camaro
i apologize i knew i was forgetting to mention something.
what is the stock flywheel tooth count on my 305 because if it is 153 i will use my existing starter until it burns out then replace it with a better one.
Old Sep 21, 2010 | 02:59 PM
Car: 1992 RS
Engine: Carbed 350
Your stock starter should be 153 tooth - I think all the 3rd gens had 153 tooth flywheels since the T5 was too small for the 168 tooth wheel.
Old Sep 21, 2010 | 06:20 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Just look at your stock starter.
If the 2 mounting bolt holes are in line then is 153.
If bolt holes staggered then 168 tooth
Old Sep 21, 2010 | 09:24 PM
Abubaca's Avatar
The Zoom (number two) flywheel is made in China (ask me how I know), and is not SFI approved.
considering if it DOES fail, there's a fair chance it could send hot shrapnel through your ankles, it's really up to you! Chances are for mild applications you'd be fine, but......I went with GM.
*EDIT* ---according to summit, that GM FW isn't SFI approved either. Hmmm. Still, I'm not a fan of a knock-off Chinese part. Nice people, awesome food, crappy quality.
Old Sep 21, 2010 | 09:29 PM
endo666's Avatar
Car: 84 Camaro
im open to other suggestions too. those were just 2 that i picked out as possibilities.
Old Sep 22, 2010 | 09:08 PM
Abubaca's Avatar
I got the same flywheel, but in Steel, not nodular iron. It added about 10 pounds, but lots of people seem to be unhappy with the idling characteristics of the lighter flywheels. ...I've been real happy with it. Although I did pay about $30 bucks less back in the Spring.
Here's the comparo:
http://www.summitracing.com/compare.aspx
Caspar
Jun 19, 2016 11:19 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
Trickskier
Aug 29, 2015 01:12 PM
Cleotiz
Aug 22, 2015 01:54 PM
redmaroz
Aug 16, 2015 11:40 PM
