305 heads
Old Sep 23, 2010 | 03:42 AM
jay173's Avatar
305 heads
Do the carb,tbi and tpi 305 engines use the same heads?
Old Sep 23, 2010 | 11:04 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 305 heads
No.
TBI 305 used swirl ports, 187 casting number I believe.
Carbed used 416's typically.
TPI used 091's I believe. The 416's and 091's are pretty similar, but the swirl ports are the oddballs of the bunch.
Old Sep 23, 2010 | 12:57 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Re: 305 heads
TBI used 187 swirl, 87+
TPI used 081 heads for 87+
Carb heads pre-87 were 416 and 601
305 Vortec used 059 and 520 castings
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
