'88 IROC 305 TPI Engine Timing Spec
Old Sep 25, 2010 | 06:15 AM
BASSr's Avatar
Car: '90 IROC Convertible
Engine: 305 TPI LB9
Axle/Gears: 3.23 Disc Brake LSD
Anyone have the base timing spec for an '88 IROC 305 TPI motor?
I swapped this motor into my '87 el camino and the decal on the original car is long gone.
I need to set the base timing and can not seem to find it online anywhere?
Old Sep 25, 2010 | 08:10 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: '88 IROC 305 TPI Engine Timing Spec
Stock timing is 6*BTD.
Old Sep 26, 2010 | 03:33 PM
BASSr's Avatar
Engine: 305 TPI LB9
Thanks, much appreciated. Is that off the tag on your car?
I also noticed that your '87 has a 5.7 TPI w/52mm TB. Do you happen to know what size TB the 5.0 TPI '88 IROC's came with?
Old Sep 26, 2010 | 04:54 PM
red rock's Avatar
Car: 1987 iroc
I believe all stock throttle bodies are 48mm, for the 3rd gen. And by the way, the timing info is from 3 different repair manuals and memory.
BlueIroc-Z
Jun 9, 2019 03:22 AM
The_Phoenix
Sep 3, 2015 10:56 PM
Brcharrelson
Aug 26, 2015 07:47 PM
kyleb24
Aug 15, 2015 08:24 AM
drathaar907
Aug 6, 2015 04:20 PM
