Unsteady RPMs
Old Sep 25, 2010 | 10:42 AM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Unsteady RPMs
Not sure if it's a big deal but if I have my car in park/neutral and rev up to about 1300, I can watch the needle drop and pick back up even when my foot is steady. It does the same thing if I'm at a redlight or something and have my foot on the brake. It feels weird almost like a misfire.
Old Sep 25, 2010 | 11:23 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Unsteady RPMs
set up the coil wire so its close enough to the terminal on the cap for the spark to jump. with the engine running see if the spark is steady. if so your either too rich or too lean. black smoke says too rich. pull the plugs and see what they say. and go from there.
Old Sep 25, 2010 | 02:51 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Unsteady RPMs
Vacuum leak maybe?
Old Sep 25, 2010 | 04:16 PM
InjectorsPlus's Avatar
Former Sponsor
Re: Unsteady RPMs
Vacuum leak, IAC, or injectors.
Old Sep 25, 2010 | 05:09 PM
Mr Froman's Avatar
Re: Unsteady RPMs
Ok I'll clean my IAC valve and I think the running rich idea might be it considering I have headers with an exhaust leak.
Old Sep 25, 2010 | 05:16 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Unsteady RPMs
Good responses. Weve also seen issues with timing control cause irregular idle. Check with a timing light for unusual changes in timing. It may be the ign module.
Elephantismo
Feb 13, 2019 12:51 AM
ULTM8Z
Oct 2, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
Damon
Sep 26, 2015 04:29 PM
