ZZ4 Oil Pump Question
Old Sep 25, 2010 | 04:06 PM
*84TA's Avatar
Car: 84 Trans Am
I just picked up a used ZZ4 short block. It was missing the windage tray and oil pump. The GM oil pump that came with the motor part # 93442037 is close to $100. Would I be okay running a Melling or even a Jegs/Summit brand Pump. I was looking at the Melling M55, but Iv'e read that there has been some problems with the hosing cracking and the pumps locking up. Also what is this talk about de-burring and checking the pump for clearance?
Old Sep 25, 2010 | 04:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: ZZ4 Oil Pump Question
The M55 with an IS-55 shaft, 55-S1 pickup and the Mr. Gasket 26 relief spring would do fine.
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
92camaroJoe
Aug 13, 2015 06:07 AM
