My cars oil pressure is at 50 when idling cold. When it gets warm it idles at 18psi, revs up to about 30psi. This is on a mechanical oil gauge. Running straight 30 weight.
Former Sponsor
Quote:
It's not perfect, but it's not horrible. Probably some inaccuracies in the gauge and some bearing clearances off. Originally Posted by 86camaroZ
My cars oil pressure is at 50 when idling cold. When it gets warm it idles at 18psi, revs up to about 30psi. This is on a mechanical oil gauge. Running straight 30 weight. When the motor was built what were the main clearances? If tight, say .002, thinner oil will be better, if sloppy, say .0050, you want thicker oil.
