1988 305 tbi wont stay running
Old Sep 28, 2010 | 07:49 PM
trafficlightguy's Avatar
Car: 1988 iroc
Engine: 350 30 over
Axle/Gears: Series 2 373
Hi,
my sons first car a 1988 camaro 305 tbi , I installed a flowmaster 80 cat back, Sunday he drove the car 10 miles ans let it sit for 2 hours then drove home when he dropped is girlfriend off it started to sh*T and sputter, He pulled the car over and called I thought it was a bad gas gauge, not. the exhaust was very hot so I thought clogged cat so I gutted it, stille no luck I borrowed a code reader not error codes I replace the map sensor not luck, but when I jam the egr valce open it run but the idle is very rought jumps betwwen 750 ans 100 rpm then dies, so I removed the egr valve it operated up and down no restriction in movement, I also checked all the fuses, and there are no vacuum leaks.
I need to pump the pedel to try to keep it running
ANY HELP OR SUGGESTION IS WELL ADVISED
thanks
chris the trafficlightguy
Old Sep 29, 2010 | 10:34 PM
Car: 1988 iroc
Engine: 350 30 over
Re: 1988 305 tbi wont stay running
update spoke the orginal owner he said he was having a problem with the dist control module change that and still nothing.
EGR valve DONE
MAP DONE
DIST Control DONE
I think Iam going to take it to a shop seems like something I cant figure out
Old Oct 2, 2010 | 08:15 PM
Car: 1988 iroc
Engine: 350 30 over
EGR valve DONE
MAP DONE
DIST Control DONE
well replace the computer and that was it either, so i took it to a mechanic
Old Oct 3, 2010 | 08:53 PM
torque_is_good's Avatar
trafficliightguy, exhaust tends to be very hot. if it was hotter than normal, then the engine is running lean and you might be looking at bad O2's or a fuel pump or pressure regulator.
if the spark is good, and timed correctly, and there is now restriction to air entering the engine, and no restriction to air exiting the engine, then you're left with fuel
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
