ticking noise behind dash?
Old Sep 29, 2010 | 04:42 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Ok, my car is a 91' 350 tpi. Had a problem with my car shifting late and the gas pedal sticking to the floor and then coming up slowly. Ok, so i narrowed it down to a piece of rubber getting in the way of my accelerator cable behind my gas pedal. Problem fixed,but now i am getting a faint clicking sound from behind my dash. As far as i know my 91' has an electronic speedometer. Looks like a regular analog unit though. So wtf is that ticking noise from?
Old Sep 29, 2010 | 05:38 PM
comeau331's Avatar
Car: 1986 Trans Am
Engine: Stock 305
Axle/Gears: not sure...
Re: ticking noise behind dash?
I've heard something similar... not so much a tick but almost sounds like a thump? I haven't had time to look into it as mine does it only when driving and between 1200-1600ish... Have you tried tightening the bolts on the trim/plastic pieces on the dash? I had a ticking sound and it was the cover under the passengers side dash..
Old Sep 29, 2010 | 06:18 PM
ninetyone's Avatar
Axle/Gears: 3:42
no,no, this is a faint tick,tick,tick,tick as i accelerate. It only increases in speed as i accelaerate too. Kind of like on the older car's when a speedometer cable is touching part of the car.
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
corey8084
Sep 17, 2015 02:56 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
Stryker412
Sep 7, 2015 09:11 AM
