oil cooler can just plug them off?
Old Oct 3, 2010 | 07:13 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i was wondering can i just plug the two hoses? or can i take a small piece of hose and jus run them to each other? dont need but filter wont go on without in , and previous owner already plugged it off at heater core.
Old Oct 3, 2010 | 10:01 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: oil cooler can just plug them off?
If you are talking about the cooler that fits between oil filter and block , you can leave the holes open if no coolant lines hooked up.
You have to change the bolts that hold the oil filter adapter out for regular hex head ones that don't have the studs on then to locate the cooler.
Then you can delete the cooler altogether and just fit the filter to the block as normal
Old Oct 4, 2010 | 04:13 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
ok ty,
Old Oct 4, 2010 | 04:33 AM
Twin_Turbo's Avatar
Simply remove it, it spins on, if you remove it the filter will spin on the regular oil filter adapter.
You can remove the liens and hook the lnie from the hard line on the frame direct to the rad
toronto formula
Nov 10, 2015 06:17 AM
LittleFranks
Sep 17, 2015 12:22 PM
gixxer92
Sep 1, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
