knock sensor question
Old Oct 7, 2010 | 03:46 PM
Rob's 92 gta's Avatar
Car: 92 firebird gta
Engine: L98 with minor mods.
Will the knock sensor detect a knock from say a main bearing or rod bearing or will it only detect detonation from pre ignition ? Just curious.
Old Oct 7, 2010 | 05:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I've heard it can pick up other noises, but I can't say from first-hand experience that it will.
Old Oct 7, 2010 | 10:53 PM
mlynch001's Avatar
Car: 1985 El Camino SS, 2004 Trailblazer
Engine: Hybrid 305, 91 SD TPI, lots of mods
Transmission: 200-4R
Re: knock sensor question
YES! One way to test that theory is to take a small hammer and tap on the block or oil pan rail near the sensor. DO NOT HIT THE SENSOR. The timing will retard and the engine will slow down slightly! The knock sensor is a microphone that "listens" for the telltale sounds created by detonation (spark knock). The knock sensor will also pick up noisy gear drives, loose pistons, wrist pins, rod knocks, etc. That is why almost all gear drives have the disclaimer "not for use on computer controlled vehicles with knock sensors"!
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
gwade12
Aug 8, 2015 08:17 AM
