MAP sensor
Old Oct 9, 2010 | 12:38 PM
lanmankilla's Avatar
Car: 84 Z28
Engine: LG4
MAP sensor
Hello all,
I cannot figure out where the vacuum line for the MAP sensor runs/connects to, any help would be greatly appreciated.
Old Oct 9, 2010 | 01:48 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: MAP sensor
It connects to the vacum nipple on the side of your plenum(passenger side). The fatter of the two nipples.LOL
Old Oct 9, 2010 | 02:33 PM
Car: 84 Z28
Engine: LG4
Re: MAP sensor
Okay thanks that gives me a better idea but i'm assuming you meant for a TPI what about a carbureted third gen? Thanks
Old Oct 9, 2010 | 03:26 PM
Car: 84 Z28
Engine: LG4
Re: MAP sensor
What is the difference between these two pictures, and is the one with the blue connector not supposed to have anything hooked up to it? The damn haynes shows both pictures and says a MAP can be on either side well it looks like I have both? I just need to hook up the blue connector sensor
Old Oct 10, 2010 | 09:27 PM
mlynch001's Avatar
Car: 1985 El Camino SS, 2004 Trailblazer
Engine: Hybrid 305, 91 SD TPI, lots of mods
Transmission: 200-4R
Re: MAP sensor
The LG4 carb engine has two sensors, one for engine manifold vacuum with a gray connector p/n 2503679 and the one with the blue connector is the barometric pressure sensor p/n 1600683. No line connected to the BARO sensor, it originally had a piece of foam glued over the inlet port. There is NOTHING to hook to the Blue connector Sensor. My LG4 El Camino has the same set up.
Old Oct 11, 2010 | 11:40 AM
Car: 84 Z28
Engine: LG4
Re: MAP sensor
That clears things up well, thank you for your time
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
efiguy
Sep 27, 2015 01:30 PM
