Serious Timing question!
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Ok, here it is. I have a 91 350 tpi. My question is this: if i increase my fuel pressure up a couple of pounds, then will I be able to raise my timing even more now? My timing is set to it's max without detonation. About a degree before detonation starts.LOL. Someone please let me know. I just remember the car feeling stronger before when i had a little more fuel pressure.
Transmission: 4L80E/4L80E
The only way the two could possibly be related is if you were running seriously lean. If you were running seriously lean, a couple more PSI wouldn't be the fix.
Ignition advance is a function of flame travel, which is affected primarily by piston speed and combustion pressure. You want to start the fire early enough to get the burning going full blast as the piston is moving down (over simplification). It's not some magic fix-all to run more ignition advance. In fact, with better combustion chamber design comes reduced advance.
