First start up questions. Build 355.
1977 4 bolt main block brand new crank, rods, pistons. All new bearings . Vortec heads + comp cams retro kit (hydraulic roller setup).
The oil pump was primed and when I started the engine it showed no oil pressure at all so I turned it of after 30 seconds. I checked it with mechanical oil pressure gauge, same thing-no oil pressure. When I prime the pump the oil comes out from the back oil galley where oil pressure sensor was located, but its just comes out with no pressure.
I used Comp Cams brake in oil 10w-30. Oil pump was stock pressure/volume.
Short block was build by professional speed shop I assembled the rest. Is there anything that I would messed up that would give those symptoms?
Any ideas???
Thanks.
Any ideas???
Thanks.
Transmission: 4L80E/4L80E
Could be a galley plug that was left out, or cam bearing that was improperly installed.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: First start up questions. Build 355.
Gallery plug under the rear main is often missed.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The plug under the rear main will bypass the oil filter, but why would it cause a loss of pressure?
