Weird leak..
Old Oct 14, 2010 | 09:36 AM
vinny83's Avatar
Car: '83 Camaro Berlinetta
Engine: 305 with aluminum heads, voodoo cam
Transmission: 700r4 auto
Axle/Gears: 10 bolt w/ 3.73 gears
Weird leak..
well, i have a 305 in my 83 berlinetta and i just recently changed the valve cover gaskets cause oil was leakin out onto my manifolds and smokin bad lol. so i figured once i changed em, itd stop..so i did. well it stillll leaks, wtf? it comes out the bolt holes (yes the bolts are in) and leaks in between the two bolts on that long strip between them..how can i get tht to stop?
Old Oct 15, 2010 | 01:35 AM
native1031's Avatar
Re: Weird leak..
Im pretty sure a bolt kit is in order when replacing gaskets and there is leak protection that can be applied on the bolts. Any shop or auto parts store should be able to tell you.
How long did it take to change the gaskets? Mines in need replacing all the gaskets
db057
Jan 10, 2020 08:55 PM
F-body-fan
Mar 1, 2016 07:21 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
BWilcox
Sep 20, 2015 12:19 PM
