bad starter motor?
Old Oct 14, 2010 | 10:42 AM
gta90's Avatar
Car: 1990 GTA (T-Top)
Engine: 305 TPI (LB9) / 115k miles
Transmission: 4L60 (MD8 non-E)
Axle/Gears: 2.73 (GU2) 28 spline POSI (G80)
bad starter motor?
My 90GTA is making some grinding/rev noise immediately after the engine starts up, and the grinding/rev noise lasts for about 3 seconds, then everything seems normal after that. In doing some research this sounds like the starter motor is remaining engaged on the flywheel after the engine starts, which it shouldn't do. Has anyone had this problem, and can anyone confirm that this is a bad starter motor?
Old Oct 14, 2010 | 12:49 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: bad starter motor?
Sounds like it to me. Sounds like it's not retaching like it should. I believe I've had one do that to me in the past. I've also had them fail where it wouldn't engage but it would spin. It would engage but not spin... etc.
You could check the starter bolts to make sure there tight. I've had them make some noise if they ever get loose. I doubt that's your issue though.
It should be easy enough to pull it out and take it to Autozone or another Auto Parts Store. Most offer free on-site testing of starters. They verify it's in working order including the solenoid.
Old Oct 14, 2010 | 01:30 PM
gta90's Avatar
Nice handle yo!
Thanks for your reply. Good to know I'm on the right track!
Old Oct 14, 2010 | 01:36 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
If this were a new starter install, I would check for proper clearance and install shims as needed.
Frozer!!!
Jan 19, 2024 04:55 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Wesly_66
Aug 26, 2015 09:55 PM
Tonyy_z
Aug 12, 2015 07:20 AM
milk
Aug 10, 2015 06:26 PM
