Oil 10W30 or 10W40
Old Oct 14, 2010 | 02:52 PM
rvega022's Avatar
Oil 10W30 or 10W40
I have a 1986 IROC-Z with a 305 TPI Engine, it has about 140,000 miles on it. A friend on mines said that I should use a heavier weight Oil because of all the miles the car has.
I this true or should I stick to 10W30?
Old Oct 14, 2010 | 02:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Oil 10W30 or 10W40
Is your oil pressure low?
Old Oct 14, 2010 | 04:24 PM
rvega022's Avatar
When I first turn the car on the pressure is high (about 60) but when the gets to operating temperature the oil pressure is less that half (between 25 30).
Old Oct 14, 2010 | 04:45 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Your pressure is fine. You can continue running 10w30 but 10w40 wont hurt either.
I have been running 10w40 since the motor was rebuilt in 05./
Old Oct 14, 2010 | 04:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
10W40 would just eat up a little bit more HP, then.
Old Oct 14, 2010 | 08:40 PM
rvega022's Avatar
So if I use a heavier weight oil I will loos Horse Power?
If this is true, then there is no real benefit in using 10W40.
Old Oct 14, 2010 | 08:50 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Its a small loss.
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
