Who Makes A Shorter Oil Pan?
Old Oct 12, 2010 | 11:27 PM
UNSTUCK's Avatar
My oil pan is about 4 inches off the ground. It has hit the ground and now is cracked and leaking. I need to be able to get more clearance. I would think an inch or two should do it. I thought about lifting the engine up in the mounts, but wondered about getting a shorter pan, seeing as I need a new pan anyways. I understand it would take a new pick up and all, which is fine. I just can't seem to find anything.
Do you know who makes one?
Old Oct 12, 2010 | 11:39 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Who Makes A Shorter Oil Pan?
What about a C4 corvette pan?-IIRC, they have a
shorter but longer sump.I have a spare one i could
measure if you'd like to know more details..
Old Oct 13, 2010 | 08:56 PM
UNSTUCK's Avatar
Looking at pictures of the c4 pan, it looks just as big, with a longer sump area. I wouldn't mind the longer sump, just needs to be shorter.
Old Oct 14, 2010 | 09:47 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Be careful about longer sumps. I had to pull my new engine right back out after putting it in because the oil pan I bought (trying to save time by not having to clean up and repaint the original) had a longer sump by about an inch, and it got in the way when it was time to install the y pipe.
Old Oct 15, 2010 | 12:10 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
I had the same problem. My temporary solution was to clearance the pipe with a hammer. I will never use a generic oil pan again.
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
gwade12
Aug 8, 2015 08:17 AM
