Spun bearing? Thuding only when warm
Old Oct 16, 2010 | 03:09 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Well when cold the car sounds perfect. No knock, no nothing. You can rev it, you can floor it nothing. Even in gear. How ever, when it starts getting warm, it starts knocking really bad. Only when it's at idle or a little above . When reved around 3000 RPM's it goes away. Any suggestions?
Old Oct 19, 2010 | 09:02 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Spun bearing? Thuding only when warm
I don't think it's a spun bearing, and from my experience if it were a rod, it would knock always, especially at higher rpm's. I am wondering if it might be piston slap you are hearing??? Just a guess on my part there, but it is possible. Do you have good oil pressure at all times and temps?
mrbird
Oct 20, 2015 03:43 AM
HoosierinWA
Oct 7, 2015 10:15 AM
gord327
Oct 3, 2015 01:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
mfp189
Sep 27, 2015 09:25 AM
