Chevy 350/Transmission
Old Oct 18, 2010 | 10:53 PM
azfirebird's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7l
Transmission: 700r4 New Rebuilt 2011
Axle/Gears: 9 Bolt
Ok here's a question about Transmission and Engines.
My research shows that the engine in my 89 Firebird Formula 350 is a Chevy engine. (not the typically POB)
Does this mean that a 700r4 from a Chevy will fit???
and how would I tell this from looking???
Old Oct 19, 2010 | 06:57 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Chevy 350/Transmission
Yes you are right the firebird does use a chevy 350. Would a 700r4 from a chevy fit? For the most part yea. For example a 4 wheel drive 700r4 will bolt up to the motor just fine but will not work for you as is as it was designed to have a transfer case bolted to the transmission. Also the F body 700r4 although fundamentally the same as every other 700r4 has a different tail shaft housing for the torque arm to bolt to. Also there are some 700r4s that are better than others. The early 82-84 700r4s had some serious design flaws that gave the transmission a bad reputation. Later ones are fine but the newer the better. Ideally I would try to find a 700r4 from another camaro or firebird and check the date code to make sure its not one of the earlier ones.
Old Oct 19, 2010 | 07:58 PM
azfirebird's Avatar
Engine: 5.7l
Axle/Gears: 9 Bolt
Thank you That info is what I needed. Theres a guy selling one on Craigslist that is new Goodwrench. http://tucson.craigslist.org/pts/1993095492.html
If it is new then the price seems right.
Old Oct 19, 2010 | 09:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
All thirdgens have Chevy engines (except the Buick V6 in the TTA). Pontiac stopped making engines in 1981, so finding one in there would be very atypical.
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
z28venezuela
Oct 24, 2015 08:15 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
