Oil burning problem
Old Oct 17, 2010 | 05:41 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Oil burning problem
I built the motor a few years ago for my old camaro. It ran fine didnt burn any oil. Then it sat for about a year. I pulled it out and put it in my firebird. Only thing i did was change the intake to a dual plane. It runs great but at wot you couldnt see who was driving behind you it would smoke to bad. I drove it for about a year like this just never got on it.
Well i got a new car it sat for about 6 months. I decided to start driving it again and get it to stop smoking.
I changed the intake gaskets and valve stem seals, that seemed to solve most of my problem, now at wot i can see a blue haze behind the car but it is still 10x better.
Im thinking its a pcv problem. I got my dad to follow me, when i first stomp it he said it smoked a good bit but it cleaned out as i stayed in it and was hardly smoking by the time i let off.
The motor has about 15k miles total since rebuild, any ideas?
Old Oct 17, 2010 | 07:26 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: Oil burning problem
I would do a compression test.
Old Oct 18, 2010 | 08:12 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
If it was a compression problem it would smoke more the longer i was at wot, not go away.
Old Oct 18, 2010 | 09:20 PM
torque_is_good's Avatar
compression test as well as vacuum test
eightsixseven
Dec 16, 2024 01:50 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Exxon Limited
Aug 9, 2015 08:13 PM
