91 Camaro 3.1 spark problem
Old Oct 17, 2010 | 09:51 PM
pdooley's Avatar
She's only hitting on 3 cylinders.
Number 1 is dead, 3 is good, i think 5 is dead, and 2 cylinders on the driver's side are firing.
needless to say, the cars runs really rough and then stalls out.
i searched the forum for a while and discovered that the reluctor part in the distributor has a laminated magnet of sorts and cracks, which causes spark scatter and erratic timing.
No problem, I went the the auto parts store and got a cardone reman distributor.
popped it in and no difference. i know cardone is not the greatest brand, but it came with a lifetime guarantee, etc..
Edit** ok, my timing light was bad. i'm getting spark on all 6 cylinders but still will not start.
i played with the timing, made very little difference. it will try to catch but won't run.
spraying starting fluid in the intake makes no difference.
compression is 170-180psi.
anybody?
Old Oct 18, 2010 | 02:23 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Spark Is Dark
If the ignition is consistent on which ones won’t fire check for bad plug wires.
Get a spark tester so you can test it right out of the distributor cap to see where the problem is, at the cap or at the plug wire ends.
Happy Racing!
Make Noise, Turn Left, Repeat
Old Oct 18, 2010 | 04:30 PM
pdooley's Avatar
Re: 91 Camaro 3.1 spark problem
will do, thanks
edit- damn fuel injectors..
2 were bad, they checked out at 2 ohms and 8 ohms.
i unplugged those 2 and she fired up on 4 cylinders.
apparently the partially shorted injectors take out the whole bank so no fuel flows.
time to find the fuel injector thread to source replacements...
Old Oct 18, 2010 | 06:48 PM
southbay08's Avatar
we can help you out with a set of injectors. You can pm or call us at 516-492-6504
www.southbayfuelinjectors.com
info@southbayfuelinjectors.com
92camaroJoe
Jul 29, 2023 07:57 PM
db057
Aug 22, 2015 08:17 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
