305 aluminum heads with 1.94 valve
Old Oct 19, 2010 | 09:41 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
hi,
i'm lookin for 305 aluminum cylinder heads that have biggest valve of 1.94, are there any ? or can i use 2.02 valves, can i install 305 heads on 305 block anyway?
best regards
Old Oct 19, 2010 | 10:22 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 305 aluminum heads with 1.94 valve
trick flow 175's for smaller bore machines 1.94" valves
I think 113 L98 heads should work as well.
Old Oct 19, 2010 | 01:51 PM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
Here is the heads Orr89RocZ is talking about; http://www.summitracing.com/parts/TFS-30300001/
You can make a bigger valve work with out much hassle but how much bigger and how far you can lift it needs to be checked before you install. Cutting a notch/relief into the block for the intake valves helps make use of the larger valve and increase potential lift. Do some research on this before you commit. The cut should be made sparingly, removing as little as possible to achieve the desired effect and not going to, or passed obviously, the top piston ring.
Old Oct 19, 2010 | 03:45 PM
WASyL's Avatar
thank You both for quick help
best regards
Jake_92RS
Jan 28, 2020 10:37 PM
midge54
Dec 27, 2019 04:14 PM
gta90
Sep 15, 2015 04:00 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
