Has anyone used one of these brackets?
Old Oct 20, 2010 | 09:58 PM
hardyz13's Avatar
Car: 85 Firbird
Engine: 406
Transmission: 700r4 built
Axle/Gears: 3.42 posi 10 bolt
I bought one of these brackets off ebay and was wondering if anyone on here has put one on? The instruction are the same as the one they sell from march, Im am using a power steering pump that has a key pulley "I believe saginaw".
bracket http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
march instructions http://www.marchperf.com/instruction...structions.pdf
and if anyone can fix the title so I don't sound stupid.
Old Oct 20, 2010 | 11:07 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Has anyone used one of this?
To edit the title of a topic, if you go into the "edit" mode, then select "advanced edit" you can modify the title of a topic. Otherwise, I've not installed one of these so I can't help you there. Sorry.
Old Oct 21, 2010 | 11:29 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Re: Has anyone used one of these brackets?
I tried one - it would not work. I tried everything for days, there was no way it would work on my car - I even tried several different pumps with no luck.
I - like you - thought I'd save a buck since they 'look' identical to the March bracket. Not the case - it was money wasted. If you can't see a way of making it work after a few hours of trying - toss it in the trash and call it an expensive lesson learned, and then order the March bracket - I had the March bracket installed in about an hour, after days of screwing with that ebay crapola. In the case of p/s pump brackets, you really do get what you pay for!
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
armybyrd
Sep 26, 2015 03:37 PM
