MAF HELP !!
Old Oct 22, 2010 | 11:18 AM
86 Camaro joe's Avatar
Car: Camaro
Engine: 2.8 tune port
MAF HELP !!
if you where to clean your air intake with armor all spray on the out side
can that cause your maf to break ?
i got code 34 after cleaning the out side with water and soap and spraying
with armor all .. is it sucking in fumes of the armor turning on my check light ?
Old Oct 22, 2010 | 11:32 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: MAF HELP !!
your maf wires may be coated with the armor all and not getting a correct reading. try cleaning it off first with a maf spray cleaner and see if it fixes the issue
Old Oct 22, 2010 | 03:32 PM
Car: Camaro
Re: MAF HELP !!
thanks trying it out im cleaning air filters. maf with maf cleaner and wires ,
Old Oct 23, 2010 | 11:56 AM
Car: Camaro
Re: MAF HELP !!
i cleaned out the maf with maf cleaner and wires, and cleaned k&n air filters with
k&N cleaner .
unhooked the battery to reset the error codes
and restarted the car and it started fine drove perfect and even a lil more power
but still the light it on reading code 34 ..
Old Oct 24, 2010 | 07:14 PM
jwande's Avatar
Car: 92 Jamaican Yellow Firebird
Engine: 305 TBI
Re: MAF HELP !!
My book shows a code 34 as the vacuum sensor circuit. The recommended solution is to:
  • check wiring leading to terminals 20, 21, and 22 of the ECM.
  • Check the connection at the ECM.
  • check the vacuum sensor wiring and connections
  • replace the vacuum sensor (located on the firewall to the right of the brake booster)
Old Oct 24, 2010 | 07:19 PM
jwande's Avatar
Engine: 305 TBI
Re: MAF HELP !!
HANG ON! The revision section of the manual shows code 34 for MPFI V6 and V8 to 1989 as the MAF sensor.
  • Low airflow indicated.
  • Check terminal C on the MAF sensor. It should be about 0.5 volts at idle and 4.7 volts at WOT.
  • Trace the wire from terminal C and look for a short to ground.
  • Replace the MAF sensor.
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
