SLP Tri Y Header Collector Gasket NEEDED.
Old Oct 23, 2010 | 07:30 AM
ls1fiend's Avatar
Car: 1985 z28, 1994 Sierra
Engine: 350, 350
Transmission: T-5, 4L60E
If anyone can help me out by making me a couple of sets of this gasket or telling me where I can order some I would be so thankful. I can't get ahold of ROL for some flipping reason and I need new gaskets. So dadgum ticked off at SLP's stupid gasket design.....
Old Oct 23, 2010 | 12:46 PM
Damon's Avatar
Re: SLP Tri Y Header Collector Gasket NEEDED.
I never used that exact set of headers so I'm not sure why this would be a problem. But have you tried contacting SLP? They're still around over in Toms River, NJ. Link:
http://www.slponline.com/slp_contact/contact.asp
Old Oct 25, 2010 | 12:52 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
I made gaskets to my slp tri-y's graphite gasket material what has steel wire reinforcement between graphite.Has been worked good three years.
Old Oct 25, 2010 | 09:13 AM
ls1fiend's Avatar
Engine: 350, 350
What exactly did you use to cut it and to drill the holes?
Old Oct 25, 2010 | 09:38 AM
jwande's Avatar
Car: 92 Jamaican Yellow Firebird
Engine: 305 TBI
Use red high temp silicone. A guy running circle track cars told me about that. No more burned header gaskets. I used them on the heads and on the collectors. Stays flexible, seals great.
Old Oct 26, 2010 | 12:32 AM
z 28 jari's Avatar
Engine: 385
I cut holes tools like this: http://www.etolatoolbox.fi/webcatalo...ml?uid=6704961
and cut gasket to shape cutter like this: http://www.malmintera.fi/kapa-leikkurit.htm
1992 Trans Am
May 10, 2023 07:19 PM
Wesly_66
Aug 26, 2015 09:55 PM
beast94
Aug 20, 2015 06:44 AM
Out-Cast
Aug 17, 2015 10:57 AM
