main bearings .010 undersize
Old Oct 23, 2010 | 06:29 PM
MikeSammy's Avatar
Car: 1986 Pontiac Firebird
Engine: 357ci 400hp 4BBL
I have been working on an engine that I bought ( chevy 350 ) and found that the main bearing say .010 since the original owner had it ground .010. My question is would the rods have been ground .010 as well. I think the rods are ground but not sure. The rods have obvious scratches where the bearing go like how an engine bore looks, and the rod bearings say michigan 77 and has a stam saying 010. Will standard bearing s work in this engine, Someone told me that running standard bearings will cause the bearings to spin and the crank and rods won't move.
Old Oct 23, 2010 | 07:19 PM
Re: main bearings .010 undersize
Generally, if a crank needed the mains ground, the rods were just as worn if not more so. So generally, yes if the mains are .010" under the rods are too, maybe more.
Since the rod bearings say "010" it's a pretty safe bet the crank journals are .010" under as well.
Only way to be sure however, is to whup out your trusty micrometer and measure.
No std bearings will not work on a .010" under crank. There will be about 10 times too much oil clearance, and the motor will have NO oil pressure whatsoever, and it will blow up probably within the first 10 minutes of operation. No serious consequences though, just a wiped-out crank and it'll need a new set of bearings and all the metal shavings rodded out of every oil passage.
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's possible the crank pins were also ground, but by no means certain.
Material has been ground off the crank, so standard bearings aren't too small, they're too big. They won't seize, they'll rattle around and you'll have no oil pressure.
Old Oct 23, 2010 | 10:04 PM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
When rods are refurbish they just hone them enough to true the circle with the rod caps. To be sure like the other post said you will need a micrometer. It is normal to have the hone marks on the rod cap ends.
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
gord327
Oct 3, 2015 01:25 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
mfp189
Sep 27, 2015 09:25 AM
