Engine squeal under heavy accel
Old Oct 23, 2010 | 01:47 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
When I get on it (in any gear) my car emits a loud squeal from under the hood somewhere. It starts to become audible about 3000 RPM and gets louder the longer I keep my foot in it and climb through the RPM range. I've ruled out the transmission and it definitely seems to be coming from the front. The interesting thing is that the sound does not increase or decrease in pitch as the RPMs change. It just gets louder. It sounds like a dry rusty old bearing or something. If I'm at a stop and rev it to redline I do not hear the sound at all, only happens under load so this would seem to rule out the belt or any accessory. Any ideas?
Old Oct 23, 2010 | 04:14 PM
jwande's Avatar
Car: 92 Jamaican Yellow Firebird
Engine: 305 TBI
Re: Engine squeal under heavy accel
Two thoughts. First, if you have a broken motor mount, it will raise the engine up and you can hit an alternator on the hood which is spinning. Next thought, something wrapped around the driveshaft? There is a torsion bar from the rear axle to the transmission. If the bolts have backed out of the bracket and the bar is free, it can screech on the drive shaft.
Old Oct 23, 2010 | 05:45 PM
sandiegobird's Avatar
Car: 92 Firebird Formula
Engine: 5.0 TBI
Have your belts gotten wet recently? Whenever mine get wet it sounds horrible just like that, but goes away.
Old Oct 23, 2010 | 07:42 PM
johnson7454's Avatar
it still sounds like a belt. does it stop as soon as you let off? i would check the belts by pushing down on all of them and check the play amount. If the belts look fine then check for oil on them. Get some kind of cleaner and wipe down the belts. I had a older truck that the belts would do that and it turned out to just be a build up of oil and dirt.
Old Oct 23, 2010 | 10:04 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
might be from a smog control valve or something?
(presuming that's all still in place)
try running it for a short time with the belt off to see
if the squeal goes away..
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Infested
May 22, 2018 11:56 PM
tazs2000
Jul 15, 2017 08:44 AM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
