Intank Fuel Pump Install
Old Oct 26, 2010 | 12:12 AM
oguin_studking's Avatar
Car: 1990 Firebird Formula
Engine: 358
Transmission: 700-r4
Installed a new pump posted a few on different threads & diffently felt like there should be a single thread devoted to this problem!
Went to replace my intank pump due to it not working. Tried to pull the plug off the old pump & wow the plug is melted to the pump. Well the new pump came with a new plug & wires for it. Great...well i start rewiring the pump wires for the intank pump & really got worried about how to cover the new wires after connecting them to the old. Heat shrink is what i used to cover the wire connecters but im worried about it dissolving in gas...anyone have any comments on this???
I did read on the walbro intank installation instructions that you are supposed use heat shrink, but is it a special kind of heat shrink???
Old Oct 26, 2010 | 03:06 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Intank Fuel Pump Install
nope heat shrink is fine for the wiring, i left mine open in there, i used a zip tie to hold the wires in place
Old Oct 27, 2010 | 12:55 PM
Engine: 358
I preciate that tip man....def gnna do the zip ties in there so those wires dont come close to touching. But i already ordered some high dollar heat shrink last night. They supposedly use this stuff in the millitary. Its pretty much bullet proof. You can pour straight acid on it & it will not dissolve.
Old Oct 27, 2010 | 03:00 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Where are you filling up that you need acid proof heatshrink? Lol
Old Oct 27, 2010 | 03:53 PM
Engine: 358
I'm just gnna be runnin' 93 but i think i'd rather be safe than sorry, bc i dont really feel like havin' my car exploding!!! I didn't know at the time if reg. heat shrink would work...so i googled "teflon heat shrink" and found this stuff http://cableorganizer.com/heat-shrin...l.htm#features badass stuff...we'll see how good it is.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
