87 vette aluminum heads , swap L98 GTA
Car: 99 3000gt 88 gta vert 88 gta h/t
Engine: v6 /5.0 /5.7
Transmission: at/5 speed/at
Axle/Gears: ? /3.45/3.23
Has anyone info on this have heads, just heard they have problems keeping head gaskets sealing.Anyone know for sure?
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Re: 87 vette aluminum heads , swap L98 GTA
This is a fact,although with a good quality head gasket,such as a Fel Pro 1003,and good head bolts,along with a proper retorque after a couple of heat/cool cycles,you can keep them in.
That said,unless you find a fantastic deal on a pair that need absolutely nothing,they really aren't worth messing with.They aren't a horrible head,they just aren't really a good head,either.Outside of being aluminum,there's really nothing special about them.
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
I've been curious about these heads too. In Lingenfelters book he says they are a great flowing head in ported form for a torquey DD. Sure the same can be had with the iron castings, but AL saves weight and allows for more timing and compression ratio.
Edit: Did my research. For the $ and attributes of my current setup I'm going with porting my 083 heads.
