Headgasket to alloy heads question
Old Oct 27, 2010 | 01:00 PM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Hi,
friend of mine has 383sbc at 3-gen firebird(stock height block,trickflow heads with 0.039in thick fel pro head gasket)
Pistons are about 0.0157" at hole at tdc.He likes to get quench to right area(~0.04").
Is there any problems if he uses clevite nitroseal 0.026" thick gasket?
Other opinion what he thinks is to use fel pro 0.015" thick rubber coated steel shim gasket.Is that ok gasket with alloy heads?Quench is maybe little too tight with those gaskets(0.0307")
MustangBeater20
Oct 29, 2022 09:20 PM
Mickeyruder
Sep 2, 2015 02:45 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
