1984 trans am drag car roller whats it worth?
Just wanting to know what you guys thought this is worth
Heres the details:
2x3 box frame
ladder bar set up
fuel cell with braided line
from back of the seat all the way to the rear bumper is aluminum
all painless wiring with over head switch panel
10 point roll cage
narrowed rear end with coil overs
12 bolt rear end 4.88 gears with full spool
holley blue fuel pump and regulator
msd 2 step and msd ignition
weld rims rear with slicks 31x14.5
deep cycle batteries (2)
tach and guages
race seat with 5 point harness
ratchet shifter
Body is decent couple dents
car weights 2980 without a driver and all glass windows
fiberglass hood
This is a roller so no motor or trans
The starting price was $5000
I personally think thats pretty high for a roller car, what do you all think?
any questions let me know
Heres the details:
2x3 box frame
ladder bar set up
10 point roll cage
tach and guages
ratchet shifter
fiberglass hood
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: 1984 trans am drag car roller whats it worth?
Well, between the car and the parts there is definately 5k there. Is this a full-frame car? If so, then most DEFINATELY! A friend of mine just sold his roller drag car for 10k in similar cond. (Full-frame) with full alum floors and mostly fiberglass body (Doors, fenders, hood, front bumper cover, hatch.) It takes a lot to full-frame these cars. A lot depends on the quality of the work... Is it a certified chassis? That says a lot for the value if it is...
Ill have to check up with the guy and see.
Thanks for your input so far
Car: 84 Trans Am
Engine: Turbo 301
colton_carlson
Mar 8, 2019 12:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Let's see what happens after tommorrows election. maybe the economy will pick up, and your car will sell like hotcakes. good luck.
