soaking lifter ?
Old Oct 29, 2010 | 08:42 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
soaking lifter ?
i read i should soak lifters in oil for 12hrs prior to install. So i did. Problem is i forgot to take them out seeing plans got backed up before assembling my motor. They have kinda been soaking for a month . Would that matter or am i going to be ordering new lifters?
Old Oct 29, 2010 | 08:52 AM
suks2bu37's Avatar
Car: 1983 Pontiac Trans Am Daytona Pace
Engine: 305 Crossfire injected
Transmission: 700R4 with shift kit
Re: soaking lifter ?
They will be just fine. The reason you soak the lifters is to prime them with oil. Soaking allows the air to slowly release from the lifter. The added time doesn't hurt at all.
suks2bu37
Old Oct 29, 2010 | 09:27 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Hopefully they're going to be soaking in oil for years inside the engine.
Old Oct 29, 2010 | 09:44 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
good deal
i hope so too, aslong as it doesnt blow up on me when i hit it with the nitrous next year lol
Old Oct 29, 2010 | 10:10 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Doesnt matter really but you didnt have to soak them anyway. Just put some oil on the rollers and into the bearings to loosen them up, and lube the lifter bores/outside body of the lifter and install them. Dont need to be soaked in oil.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
skinny z
Oct 5, 2015 06:23 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dimented24x7
Sep 6, 2015 03:51 PM
