Can you determine compression ratio with a compression test?
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
I had a motor built for me a few years ago, and I can't remember what the engine builder told me was the ratio
Any way to determine?
Any way to determine? Senior Member
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: Can you determine compression ratio with a compression test?
Yeah, pull the heads, unless you know the piston thats in it and the cc of the combustion chamber of the heads. There are alot of variables. but no easy way other than to pull it apart.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Worn rings, bad valves or valve guides and even different cam grinds can easily change a compression test result so there's no way it can be used to determine a compression ratio.
As mentioned above, without knowing piston design and combustion chamber size, it'll have to be torn down to find the ratio.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not to mention it's pretty likely that no two gauges will give exactly the same readings either.
383,5.7 rods,afr 195 street heads,74 cc combustion chamber, xfi 280 cam,,srp flat top -5cc. the block was "4 cornered"? Don't remember how far he left the pistons in the hole. An approximate CR from this info guys? Oh the engine has about 1-2 "light break in" hours on it
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
bbc, built, check, compresion, compression, determiining, determine, determining, easiest, engine, heads, ratio, test, tester, transmission
