i need help with my block
Old Oct 31, 2010 | 09:16 PM
IZIBAKEMIZI's Avatar
Car: 89 gta
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt 383
i have a block that is stamped 010207 and i only see 14010207 why is it missing the 14 and is this a good block or should i use my 3970010 block
Old Nov 1, 2010 | 09:11 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Re: i need help with my block
Re-read what you wrote. Numbers seem to be backwards. "i only see 14010207 why is it missing the 14".
How can you see it then say it's missing?
Jake
Old Nov 1, 2010 | 09:54 PM
Either would be fine; nothing special about either one, either good or bad. Both are just ordinary typical blocks from their time periods. The 207 is newer though, it's from the early 80s like 81 or 2 up to 85 and so wouldn't have any chance of having the crappy 70s quality control issues that plagued motors all through that time frame. So if all else was equal, I'd probably prefer that one. It'll also have the dipstick on the pass side and the newer style of the 2-pc rear main seal oil pans.
Old Nov 1, 2010 | 10:05 PM
Car: 89 gta
Engine: 357
well the 3970010 is the high nickle 2 bolt and the other is a 4 bolt
Old Nov 1, 2010 | 10:06 PM
Car: 89 gta
Engine: 357
on the block it says 010207 and when i serch on line it a 14010207
Old Nov 2, 2010 | 01:14 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Popular Myth
010 probably the common garden variety SBC block cast
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
