put roller rockers on now making alot of noise
Old Nov 1, 2010 | 06:21 PM
t.p.engineerin's Avatar
Car: 88 iroc/87 k10 pickup
Engine: 357 carb/305 tbi
Transmission: 700r4/700r4
Axle/Gears: 3.42/3.42
got a 305 tbi and put new valve seals and roller rockers and now its making alot of noise thought it was the valve adj so i readjusted a few were loose but im almost positive there right now its still making noise thought maybe roller rockers just do tht
Old Nov 1, 2010 | 06:28 PM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
Re: put roller rockers on now making alot of noise
Did you verify proper pushrod length with the new rockers? Did you get New rocker nuts? In some cases rockers can just be noisy.
Old Nov 1, 2010 | 09:02 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
More details needed.
What rockers are you using?
What method did you use to set the lifter preload?
Did you change the rocker ratio, say from 1.5 to 1.6? If you did, what springs are you running?
Jake
Old Nov 1, 2010 | 09:10 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The roller rockers will make a sort of audable mechanical noise when in operation, but it shouldnt be loud, nor should it clatter.
Are they SA type rockers?
Also keep in mind that some TBI engines came with heads that have guide slots. This can cause potential issues if the rocker wants to align itself one way, but the guide slot wants to align another.
Old Nov 1, 2010 | 09:58 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Full roller rockers are rarely referred to as quiet, they are at least "growly" due to the needle bearing fulcrum. Additional noise can be heard at the roller tips, even when adjusted properly. There should be no clatter or distinct tapping going on once warmed up.
Old Nov 2, 2010 | 01:12 AM
i think i fig this out and there roller tip i had them on a motor in a camaro that had a spun bearing so i dont kno much about them but i believe there 1.5 the loud noise i think is because i have a bad lifter and the noise is louder now because the roller tip does this make sense? im thinking there prolli not doin no good on a stock motor so should i just put the stock ones bak on? also it started smokin again so why do yall think that is?
Old Nov 2, 2010 | 04:31 PM
JakeJr's Avatar
Axle/Gears: 3.07
With all the complaints being posted about excessive rocker arm noise I was pleased to see the big cam companies are now tightening their specs and quality control on the bearings.
That's just one step they're taking in an effort to quiet things down.
Jake
theshackle
Sep 17, 2020 08:26 AM
midge54
Dec 27, 2019 04:14 PM
BlackBoulder
Aug 11, 2015 11:15 PM
BrianI
Aug 9, 2015 11:52 AM
