New engine causing possible trany problems
Old Nov 10, 2010 | 12:05 PM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
I have an '82 Camaro Berlinetta, about 3 months ago I replaced the 305 with a 350. Ever since i got the new engine, i get this awful grinding noise during harder acceleration. I took it to a local trany shop and they looked it over, said it was a bearing problem. I spent $850 for a new axle saving bearing and at first the problem is solved but recently its started up again. some people have said that with the new bigger engine its contorting the drive train and causing it to grind the bottom of the vehicle. has anyone had a problem like this before? or at least have an idea of what it could be?
Old Nov 11, 2010 | 03:07 AM
Sexonfire14's Avatar
Car: 88 GTA
Engine: 350 tpi
Re: New engine causing possible trany problems
your tranny is probably not used to the higher engine power. and it might get damaged.
Ghettobird52
Jul 5, 2024 11:18 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
