Belching smoke
Old Nov 11, 2010 | 04:56 PM
TheNewStyle's Avatar
Car: '88 Formula
Axle/Gears: Stock
Belching smoke
Guys, 1988 350TPI, belches smoke when she starts (warm) and then only smokes a little. I'm guessing she's burning oil due to valve guides or seals. But why the massive amount of smoke at warm start?
Thanks,
Old Nov 11, 2010 | 05:13 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: Belching smoke
Maybe your oil is hotter and thinner and running down the guides more. Try some after market oil seal conditioner and or thicker oil. This won't cure the problem, but might lessen it.
Old Nov 18, 2010 | 01:36 PM
Car: '88 Formula
Axle/Gears: Stock
Re: Belching smoke
Thanks bro
Old Nov 19, 2010 | 06:26 AM
SoCo80p's Avatar
Re: Belching smoke
if it's a blue color, it's no doubt oil from bad valve guides/seals.
Old Nov 19, 2010 | 07:21 AM
jwande's Avatar
Car: 92 Jamaican Yellow Firebird
Engine: 305 TBI
Re: Belching smoke
Try synthetic oil - smoking disappears.
Old Nov 19, 2010 | 02:38 PM
red rock's Avatar
Car: 1987 iroc
Re: Belching smoke
If your guides or seals are bad, it won't go away. It might lessen it to almost not noticeable, but it won't go away. Worn guides are worn, cracked dry seal are cracked, the only fix is to remove the heads and rebuild them.
Old Nov 19, 2010 | 04:30 PM
Car: '88 Formula
Axle/Gears: Stock
Re: Belching smoke
I got new heads! Should help fix things
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
