trouble with my 350 vortec??? can inty one help!!! only car!!
Old Nov 14, 2010 | 07:48 PM
COTY'S IROC-Z's Avatar
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
my motor was a L98 i took a set of 350 vortec heads an made it a 350 vortec.. it got a air gapintake... it has a 650 cfm carb on it .. it ideal good take fuel good un till... you punch it flat on the floor from a ideal.... when you do that it pops throught the carb... but just easing into it it dose good... what do you that would be the problem???? please help....all help will be thankful for it!!!!!!!
Old Nov 15, 2010 | 09:20 AM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Re: trouble with my 350 vortec??? can inty one help!!! only car!!
That often means your timing needs to be advanced more. "Most carb problems are usually ignition problems"
I did a lot of searching on here to see what the most commonly agreed settings are for vortecs. I'm going to assume you switched to a vacuum advance like you're supposed to when you got rid of the computer carb. With your vac disconnected you want about 32 degrees all in by somewhere between 2800 and 3500rpm (opinions on the rpm varied a lot between people). Vortecs need less than the usual 34 to 36. You'll need a set of different springs to adjust how soon your advance comes in.
Your idle would be about 12 degrees ideally, but theres not much you can do to change that unless you find a way to adjust the limit of your mechanical advance. Having that 32 around 3000 is more important, just deal with whatever your idle advance is.
With the vacuum hooked up, you want to limit that so it'll only give you another 10 or 12 degrees. In stock form mine was giving me like 25. It was knocking like crazy. Look at the last picture on this page http://temp.corvetteforum.net/c3/joe..._Recurve.shtml see that piece of blue metal held in place by the vac canister mounting screw. I made something like that out of sheet metal, not as fancy but works fine.
This will only put you at a good starting point. From there you adjust different things listening for knocking under all sorts of conditions and adjust things accordingly.
Old Nov 15, 2010 | 11:07 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Originally Posted by COTY'S IROC-Z
my motor was a L98, I took a set of 350 vortec heads and made it a 350 vortec.. It has a air gap intake... It has a 650 cfm carb on it .. it idles good, Fuel pressure is good until... you punch it flat on the floor from a idle.... when you do that it pops through the carb... but just easing into it, it dose good... what do you that would be the problem???? please help....all help will be thankful for it!!!!!!!
Fixed all that gibberish for you so people can understand wtf your saying.
Old Nov 15, 2010 | 12:17 PM
Sparkytfl's Avatar
Sneezes through the carb when he stomps on the gas. It wasn't that hard to figure out, but I do admit I checked the guys location thinking maybe he was from a non-english-speaking country.
Old Nov 15, 2010 | 12:46 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I figured it out after reading it twice. I just think that if your old enough to own a car you should be able to write a decent sentence and use semi good spelling. On a side note. I see your from the Rochester area. Dont know if you know but there's a nice local racing site around.
http://www.rochesterracing.com/
Old Nov 15, 2010 | 10:22 PM
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
no i have a 7AL msn box!!!
Old Nov 15, 2010 | 10:30 PM
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
MSD SRY!!!
Old Nov 16, 2010 | 12:37 PM
Sparkytfl's Avatar
Along with what distributor?
Old Nov 16, 2010 | 05:22 PM
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
msd
Old Nov 16, 2010 | 11:07 PM
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
well it a regular distributor but it welded up to make it work with MSD.. we had it on our race car an it worked fine..
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
