iac problems
Old Nov 15, 2010 | 07:23 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
iac problems
how do you tell if an idle air control valve is bad? my engine is idleing about 1000 RPM and i was tinkering under the hood the other day when the car was idleing and i unplugged the iac and it didnt change the idle at all, is this an indication the iac is bad?
Old Nov 15, 2010 | 07:42 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: iac problems
Not necessarily. Remove the iac and see if it and the passageways in the housing need cleaning out. Also, while it's out, very gently push the pintle back in some way to the actuator. Then while you're holding it get someone to turn on the ignition but not start the car. Or if you can place it where you can see it you can do it yourself. It should move but don't let it move more than a small distance before turning the ignition off. If it didn't move it's probably bad. If it moved it may not be bad so try other stuff first. I found it easiest to remove the throttle body and give it all a good clean. Be very gentle with the iac if you clean it and don't get cleaner inside it. Good Luck.
Old Nov 15, 2010 | 08:01 PM
Engine: L31 350
Re: iac problems
iv cleaned the passage way and the intake
Old Nov 15, 2010 | 11:44 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: iac problems
Can you feel or see it move?
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Sep 4, 2015 07:57 AM
greenyone
Sep 2, 2015 03:39 PM
86IROC112
Aug 21, 2015 07:20 PM
