1990 camaro rs v-8...5.0litre not spraying fuel injection
Old Nov 19, 2010 | 05:45 PM
superteko's Avatar
I bought this camaro from the police auction and since than I am trying to make it run, but the key I found under the seat is a Key with no electronic chip and using the vin info the dealer informed me that that particular car dont have a chip in the key. But I have the dash security light on and the key dont start the car. I built a bridge from baterry to starter motor to turn the car on but the engine rotates and dont run but will start with starter fluid and keep going while pumping the gas pedal as long I keep pumping the gas pedal than dies if I stop pumping. I also can hear the fuel pump on for a second when turn ignition to on position.
How can I make this beautiful car run normal?????
Please help.
Luis
superteko@netzero.com
Old Nov 19, 2010 | 06:12 PM
superteko's Avatar
Re: 1990 camaro rs v-8...5.0litre not spraying fuel injection
[;ease help me with your experience
Old Nov 19, 2010 | 08:07 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Is it tb or tpi? It might be your injectors are stopped up. If its tpi it gets the fuel from the electrical pulse to each injector. But I dont know how pumping the gas peddle is helping anything unless for some reason someone put a carb on it.
Old Nov 20, 2010 | 02:38 PM
superteko's Avatar
it is a carburetor with 2 injectors in the top, when I press the gas pedal it injects gas from the carb to the trought but fuel injectors are not responding
Old Nov 21, 2010 | 10:06 PM
camarofan13's Avatar
Car: 91 Camaro
I'm having the exact same problem. I think its either the injectors or your connection to the injectors. unfortunately, I don't know how to unclog the injectors. if you find out what it is, keep me posted. ill do the same.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
86Base
Aug 13, 2015 05:06 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
