start problem
Old Nov 24, 2010 | 09:56 PM
built's Avatar
Car: 82 TA
start problem
Ok I went out to start my car yesterday and turned the key and it did nothing, maybe a click but not continous.
tried it a few more times and then it started right up no dragging or slow.
today it has started fine every time, whats wrong ?
what should I check?
Old Nov 24, 2010 | 11:07 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: start problem
sounds like a bad ground, or your solenoid going out
Old Nov 26, 2010 | 12:32 AM
built's Avatar
Car: 82 TA
Re: start problem
is it possible that the battery is going bad causing this ?
how can i test to see if the starter solenoid is the fault?
it has been starting fine now for the last several days but I don't trust it.
Old Nov 26, 2010 | 01:49 AM
matts86cam's Avatar
Car: 1986 chevy camaro z28 coupe
Engine: crate 355
Transmission: 700r
Re: start problem
I had the same experience with my work truck, an F-250. Turns out after about 2 weeks the battery just gave. It had a bad cell in it. Take it to an auto parts store and they will check it for free.
Old Nov 29, 2010 | 07:08 PM
built's Avatar
Car: 82 TA
Re: start problem
took it back to the store where i bought it and it checked bad and they replaced it free .
but today it did it again, i'm going to have the alrenator checked to make sure the battery isn't running down but i'm thinking starter time again, just changed it like two years ago maybe early last year.
gotta look for the reciept.
Old Dec 1, 2010 | 08:12 PM
built's Avatar
Car: 82 TA
Re: start problem
alternator checked out ok .
I changed out the starter for a new one but the old one checked out good too but i think it was a intermitent problem and would have eventualy went out totally.
Old Dec 1, 2010 | 11:59 PM
FueledSoul's Avatar
Re: start problem
edit
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
