Oil Cooler?
Old Nov 26, 2010 | 09:10 AM
IROC343's Avatar
Car: 1987 Iroc Camaro
Engine: 383 GMPP TPI
Transmission: 5 Speed Manual
Axle/Gears: 10 Bolt 4:10 Eaton Posi Moser Axles
Oil Cooler?
I eliminated the factory oil cooler when I replaced the original 305 with a 383. I figure I saved about 10-15lbs (including coolant), eliminated two possible sources for leaks, and although I'm not a thermal engineer, the unit didn't appear as if it really could do all that much as far as cooling the oil anyways. There's got to be a gazillion small blocks running daily out there without oil coolers and I don't use the car for heavy hauling or endurance racing. Do you guys think I made a bad decision?
Old Nov 26, 2010 | 09:16 AM
Stephen's Avatar
Car: 87 GTA
Re: Oil Cooler?
You'll be fine.
My harmonic balancer came apart a couple years ago, the outer ring slid backwards & slowly ate through the factory cooler tube until it leaked.
I pulled the hard lines out, plugged it all up. Now no more coolant runs back there to cool things off & all it still good.
tyeo098
Nov 30, 2015 06:27 PM
1992Z28!
Nov 19, 2015 07:33 AM
skinny z
Oct 5, 2015 06:23 PM
CatmanFS
Sep 19, 2015 09:00 AM
apie2546
Sep 5, 2015 07:40 PM
