does heat require ac
Old Nov 28, 2010 | 06:10 PM
MikeSammy's Avatar
Car: 1986 Pontiac Firebird
Engine: 357ci 400hp 4BBL
I have been rebuilding my sbc and I am about to put the engine in. I don't care about air condiotoiing but need the heat for the winter. Is there away that I can just get rid of the ac box. I currently just have the water pump, alternator, and crank pulley hooked up. I kind of like the old school look.
Old Nov 28, 2010 | 06:24 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: does heat require ac
you can have heat without ac, just pick up a non-ac box and blower motor. heat will still work the same as before. doing this myself to gain some more room under the hood and clean things up a bit
Old Nov 28, 2010 | 07:06 PM
mightymaro94's Avatar
most ppl get the idea that "defrost" requires the a/c... your defroster will still function with out the a/c... a/c just removes the moister from the vehicle is why your car uses it with defrost
Old Nov 28, 2010 | 07:31 PM
///DAN///'s Avatar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
if i understand right the heat just cycles the a/c in defrost to keep the pump moving during the winter so it doesn't seize.
Old Nov 28, 2010 | 07:39 PM
it does that and remove moister from the system.. so i guess we are both right
Old Nov 28, 2010 | 08:09 PM
MikeSammy's Avatar
so if I remove all the ac stuff, my heat should still function, right?
Old Nov 28, 2010 | 08:13 PM
yes your heater will still function... if you search the forums you will probably find a how to .. or atleast someone who has done it before and posted on it
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
mfp189
Sep 27, 2015 09:25 AM
